Hi the LCD-SerLCDv2 is compatible with the picbasic pro serout and the commands :?:
Yep. Most compilers will have a serial out command. You’ll need to set it to 9600bps with normal (not inverted) TTL levels.
-Nathan
I am send this
SerOut LCDScreen, N2400,[LCDCmd,LCDLine1," Hello "]
and no work i see trash in the LCD
Help
how i reprogram the chip to use my code if is possible…
