which is pin 1 for starters and some of the other pins on the datasheet are too blurry to make out.has anybody figured out what pin is what and could share the info,I can’t be the only blind person out there can I ?
no not really.But if you look at the way they show the pin one position and right under it they show the end with the part number so I tried that and it worked ok
