A level shifter based on [ti’s txb0104 would be superior to [BOB-08745 in most respects, except probably a bit pricier (budgetary price $0.70 for txb0104 in soic)
the main advantages are that it would
allow any mix of directions, and even allow direction changes
operate with low vcc down to 1.2v and high vcc down to 1.65
output enable pin available
The main shortcoming is when there are pull-up resistors–the pull-up value must be above 50k.
I think that using the SOP package it would be possible to fit in the pinout and 0.5x0x6" space of the BOB-08745, but it won’t be pretty.
An 8-signal version based on txb0108 would also be a possibility (budgetary price $0.80)](http://www.sparkfun.com/commerce/product_info.php?products_id=8745)](http://focus.ti.com/docs/prod/folders/print/txb0104.html)
