I see that the LiPro Balance Charger (https://www.sparkfun.com/products/10473) does not come with a power supply and does not accept the normal 5.5 mm input. Does anyone recommend a specific product that is suitable to power this unit? Something that ships quickly and is relatively inexpensive would be ideal!!
Thank you,
Gina
              Hi Gina.
Unfortunately we don’t carry a dedicated power supply for this charger but we carry something that could be used.
It’s a bit overkill but [TOL-16266 would work. You would need to modify the barrel jack to alligator clip cable that come with the charger so that you can connect it to the power supply but that power supply is plenty large enough for the charger.
Just be careful with that power supply since it has exposed high voltage terminals for connecting it to AC power.](https://www.sparkfun.com/products/16266)
              Thanks! Do you know if that item can be shipped to Canada?
              Unfortunately no, we can only ship that domestically, but Mouser Canada can. The link below will get you too something that will work that can be shipped to Canada.
https://www.mouser.ca/ProductDetail/MEA … voUg%3D%3D
