Load cell measuring and info display
Hey!
I am working on a small sized rocket thrust tester (14N max) and I was planning on using one of the load cells from the SparkFun website.
I am in need of a way to relay that data on a force vs time graph on my laptop in real time. I have looked into using the “SparkFun Open Scale”.
My quesion is, are there any other combinations of load cells and amplifiers/transducers that might be more suitable for the task?
It would be good if it could read at atleast 80 readings per second.
Thank you.
You may want to look into the work done on this thread: https://forum.sparkfun.com/viewtopic.ph … open+scale
and by the same individual in here: https://forum.xojo.com/48919-anyone-wit … p2#p409081
He is using the Openscale, sampling at 160Hz, for rocket propulsion measuring device.
