Lora expLoRaBLE upload problems
It says:
Sketch uses 115020 bytes (11%) of program storage space. Maximum is 983040 bytes.
Global variables use 27328 bytes (6%) of dynamic memory, leaving 365888 bytes for local variables. Maximum is 393216 bytes.
/Users/wilfred/Library/Arduino15/packages/SparkFun/hardware/apollo3/2.2.1/tools/uploaders/asb/dist/macosx/asb --bin “/private/var/folders/j0/mxdzhynx7pg55j137qqq5v1r0000gn/T/arduino/sketches/DAFC936B31382CF1A1CAAC986679AEEE/sketch_apr21a.ino.bin” --load-address-blob 0x20000 --magic-num 0xCB -o /private/var/folders/j0/mxdzhynx7pg55j137qqq5v1r0000gn/T/arduino/sketches/DAFC936B31382CF1A1CAAC986679AEEE/sketch_apr21a.ino --version 0x0 --load-address-wired 0xC000 -i 6 --options 0x1 -b 115200 -port “/dev/cu.usbserial-10” -r 2 -v
Header Size = 0x80
original app_size 0x1cdf0 ( 118256 )
load_address 0xc000 ( 49152 )
w0 = 0xcb01ce70
Security Value 0x10
w2 = 0x10008080
addrWord = 0xc000
versionKeyWord = 0x0
child0/feature = 0xffffffff
child1 = 0xffffffff
crc = 0x9a5d6f8e
Writing to file /private/var/folders/j0/mxdzhynx7pg55j137qqq5v1r0000gn/T/arduino/sketches/DAFC936B31382CF1A1CAAC986679AEEE/sketch_apr21a.ino_OTA_blob.bin
testing: /private/var/folders/j0/mxdzhynx7pg55j137qqq5v1r0000gn/T/arduino/sketches/DAFC936B31382CF1A1CAAC986679AEEE/sketch_apr21a.ino_OTA_blob.bin
Header Size = 0x60
app_size 0x1ce70 ( 118384 )
Writing to file /private/var/folders/j0/mxdzhynx7pg55j137qqq5v1r0000gn/T/arduino/sketches/DAFC936B31382CF1A1CAAC986679AEEE/sketch_apr21a.ino_Wired_OTA_blob.bin
Image from 0x0 to 0x1ce70 will be loaded at 0x20000
Connecting over serial port /dev/cu.usbserial-10…
Sending Hello.
Received response for Hello
Bootloader connected
Received Status
length = 0x58
version = 0x5
Max Storage = 0x4ffa0
Status = 0x2
State = 0x7
AMInfo =
0x1
0xff2da3ff
0x55fff
0x1
0x4cd00005
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
Sending OTA Descriptor = 0xfe000
Sending Update Command.
number of updates needed = 1
Sending block of size 0x1ced0 from 0x0 to 0x1ced0
Sending Data Packet of length 8180
Sending Data Packet of length 3960
Sending Reset Command.
Tries = 0
Upload complete!
And it worked!
