Lorawan Gateway
Components
SparkFun MicroMod Main Board - Double
SparkFun MicroMod Artemis Processor
SparkFun MicroMod LoRa Function Board
SparkFun MicroMod Ethernet Function Board - W5500
I’m having trouble with the Ethernet and LoRa function boards. When I connect them to the main board, both the Ethernet and LoRa boards work fine in Function Slot 0. However, I can’t get either of them to work in Function Slot 1. Has anyone else experienced this issue or know how to fix it?
This is usually due to some of the pins needed already being used by the processor; do you happen to have an alternate MM processor you can swap in and try?
No, I don’t have another processor, and since shipping takes a long time, ordering a new one isn’t an option right now.
Darn - if it no longer suits your needs: Were the items purchased from us? If so head over to www.sparkfun.com/returns (contact vendor if purchased elsewhere) and we’ll get ya squared away
