Lpc-l2294 debugging problem
Hi all,
I am using olimex lpc2294 board. i got an error message when i am downloading
Write failed at memory (0x00010000)
Write failed at memory (0x00010200)
Write failed at memory (0x00010210)
please any one help me to rectify this problem.
Thanks in advance,
M.Y.Samraj
What are you downloading?
Leon
Hai leon,
Thanks for your response…
i am downloading port toggling program only…why it shows the warning…
Thanks&regards
M.Y.Samraj
Was the program compiled for the LPC2294? It might have been built for a chip with a different memory map. However, that is unlikely to be the problem.
What are you using for downloading?
Leon
hai Leon,
Thanks for the reply.program was compiled&build and shows no error.I am using IAR Embedded Workbench 5.0 only…I am downloading via parallel port using JTAG debugging…
M.Y.Samraj
hi all ,
when i am downloading, initially it shows some warning like this …Target inconsistency detected at memory address …please give me solution for this.
Thanks N regards,
M.Y.Samraj
The only thing I can think of is that the progrqm was compiled for the wrong target. I don’t use IAR software, try asking them about it.
Leon
