LPC2294 LCD datasheet
Dears,
I have trouble finding LPC2294 LCD model and data sheet. could you please give me some tips?
regards,
BISO
You have to more precise. There is no LCD display in a LPC2294. You probably mean some LCD on some devellopment board. If that is the case you supply the name and manufacturer of the test board.
Best regards
Esben
Hi Esben.
I’m guessing that you are referring to the Olimex LPC-E2294 DEVELOPMENT PROTOTYPE BOARD which has a 16x2 LCD display.
This is probably a standard LCD display using the Hitachi HD44780U controller operating in 4-bit mode.
Here’s a link to the HD44780 documentation: http://www.eio.com/hd44780.pdf
Here’s a link to an Arduino site with a 4-bit driver implementation that may give you some guidance on the matter.
http://www.arduino.cc/playground/Code/LCD4BitLibrary
This should give you a start.
Cheers,
Jim Lynch
Thanks a lot for your help. it was very useful
BISO
