I have two 10Hz LS20031 which are working perfectly. They come from the same order, but on one module, led is not blinking at all.
Is there a setting to make it blink ? I should also check if led soldering is ok.
Angelo
Angelo
Is the data indicating that you have a lock on sat’s?
My LED pulses only once at power on then no lock on LED or in data frames.
Steve.
Yes, I got a fix, positions, speed, alt,etc… everything is ok, except led is not blinking.
Angelo
