Is it possible to provide information(link/scheme/etc) how to connect and chain several SparkFun Lumenati 4-pack to Arduino uno? What components do I need? How many Lumenati 4-pack LEDs I can chain and turn on with white light and maximum intensity using 5V 3A power supply?
Check the two guides below, those should get you going. ![]()
With all 3colors turned on at maximum brightness, each LED will consume 60mA so the most you can have at 3 amps would be 50 but it would be wise to drop that to 45 to add in a safety factor.
