LuMini Ring Battery Problems
I bought a series of things in order to get the LuMini Ring 1" and 2" working. I received everything I ordered. However when I purchased the items that the Sparkfun https://learn.sparkfun.com/tutorials/lu … 1613364164 website directed me to buy a Mean Well LED Switching Power Supply - 5VDC, 5A. However, I do not know what type of cables/ adapters to use so that they would connect to my LumiDrive PCB. What things do I need to buy to power the PCB and ultimately the LuMini Ring?
Easiest way to connect this would be to connect the red wire from the power supply to the +5 volt connection on the LEDs and the black wire from the power supply to the GND connection. That will supply power to both the LEDs.
The blue and brown wires on the power supply need to connect to a 120 or 240 volt AC outlet where blue goes to neutral and blue goes to live.
