hey guys can you suggest any sites/software that can understand Coordinates from the GPS receiver (like google maps, wikimapia) but the thing is that i need a site that will calculate the distance between the two points (coordinates) that i input…
thanks
Vincenty formula. The gold standard for distance calculations between two points accounting for map datum. Here is a sample calculator:
http://www.movable-type.co.uk/scripts/l … centy.html
Most websites, like google maps, want lat long in decimal form and most gps modules give lat long in degree decimal minute.
Different formats
http://www.maptools.com/UsingLatLon/Formats.html
You may need to convert the formats.
http://www.csgnetwork.com/gpscoordconv.html
Be sure the distance formula you use works with the format.
Don’t forget to convert between degrees and radians.
http://www.movable-type.co.uk/scripts/latlong.html
