Matching Xbees
Ok so being a guy I went out and bought the most expensive without thinking to much about it.
I bought a
WRL-09086
XBee Pro 900 XSC
and a
XBee Pro 900 Wire Antenna
Thinking that these two could transmit signals back and forth I began playing around with sending some terminal commands
I have yet to see them talk at all even after a few days of hardcore reading.
Does anyone know if the two of these xbees will ever be friends?
i always thought that they were interchangebale Watch this:http://www.youtube.com/watch?v=G_ScqGDY2eo
Use X-CTU (http://www.digi.com/support/productdetl … tp=5&tp2=0) Update the firmware on each device, and make sure that you set them up so the settings match, Channel, Encryption, frequency, etc. Yes, they should mesh.
