MAX-M10S no communication
SparkFun DataLogger IoT - 9DOF (c) 2023 SparkFun Electronics
Version: 01.00.01 - build 00007c
[W] GNSS::isConnected no traffic seen (first attempt)
Where?
“SparkFun DataLogger IoT - 9DoF and GPS max-m10s”
Forum: QWIIC System
Reason: The reported message does not fit into any other category, please use the further information field. Please repost with a question…
Try to set up the GPS device separately https://learn.sparkfun.com/tutorials/gn … rogramming and ensure it’s working, then combine the two
Also: What antenna are you using, and are you attempting outside with a clear sky?
Hi @ vti_hakan,
Please update your DataLogger firmware. There was an issue in the original firmware which prevented the u-blox GNSS from connecting. This has been corrected in the latest firmware.
https://docs.sparkfun.com/SparkFun_Data … tem-update
https://github.com/sparkfun/SparkFun_Da … r/releases (scroll down to see SparkFun_DataLoggerIoT_01.01.01.bin)
