MAX98357A Hookup Guide code no longer works with ESP32 Thing Plus
The easiest way to describe this issue is to reference the hookup guide below:
https://learn.sparkfun.com/tutorials/i2s-audio-breakout-hookup-guide
I have a Max98357A Breakout Board and a ESP32 Thing Plus linked below:
I had these two boards functioning together about a year ago in the form of a A2DP Bluetooth speaker. Set the project aside. Came back, yesterday, updated libraries (unsure what library versions I had before) and I can no longer output audio through the MAX98357A. I’m perplexed. I’ve not rewired anything, it’s the same board that was working before. Yet I double checked the wiring and seems correct.
Core libraries for Arduino I2S & ESP32 seem to be broken? I went back to the Arduino IDE and started going through the referenced MAX98357A hook up guide to find I cannot get those code examples to work either.
Has anybody used the MAX98357A breakout with a ESP32 Thing Plus board recently? How did you get it working? Thanks!
If you still have the original project code that worked a year ago, upload it without any changes. This can help confirm whether the issue is with the libraries or something else.
Figured out how to get the hookup guide tutorial working…
I was pulling from library instead of manually adding ZIP files downloaded from hookup guide webpage. Once I manually added zips it all worked.
I also figured out my original speaker project. Similar problem, authors updated the library and documentation. However, I don’t know that they updated the example projects. I was able to get working from their documentation.
