measuring if any flow in a pipe? flow switch
i want to measure if there is any flow in a pipe . i want to use
this https://www.sparkfun.com/products/9196? … 1572498797
so to detect vibration then flow detection.
i want to know if it can be water resistance as this will be installed outside (rain).
any other cheap way for this ?
Hi biswajitjei02.
I’m not sure we have any sensors that would be good at detecting flow in a pipe.
The Piezo Vibration Sensor might work but that’s not anything we’ve tried before. You’d need to connect one to a pipe and see what happens.
As far as rain goes, you would want to keep these dry to prevent any damage to them so you’d need to figure a way to protect them from moisture.
