I think some new products that SparkFun should consider stocking are micro air pumps,
micro vacuum pumps and micro liquid (water) pumps. Usually these are small diaphragm pumps
driven by micro dc motors or piezoelectric elements and have small enough current draw
that they can be run off batteries. I have a couple of projects in mind in which I could use micro
air pumps and micro vacuum pumps. I have found some that fit the bill but find it impossible
to find distributors for these items. I don’t want to go to the hassle of trying to buy engineering
samples directly from the manufacture as they always seem to want your first born before
they will do you the favor of selling one of their products to you.
I am including links to examples of what I hope SparkFun might consider stocking. I believe
most of these items could be purchased by SparkFun for less than $10/piece in lots of 100
although this is just a guess.
[KNF
Here a examples of products that use the type of pumps I think SparkFun should stock
A few electrical controlled valves compatible with these pumps would be icing on the cake.
Could anyone else out there use something like these ?](http://www.marinemetal.com/mmpweb3.html)](http://www.caswellplating.com/models/pumps.html)](http://www.sensidyne.com/micro-and-miniature-air-pumps/aaa-series-micro-air-pump.php)](http://www.smartproducts.com/pumps_series_ap_micro_air_pumps.php)](http://www.knf.com/oemicro.htm)](http://www.welco.net/wpm1a_e.html)](http://www.bartels-mikrotechnik.de/index.php/mp6-OEM.html)](http://www.chinamicropump.com/cmp11.html)](http://www.xavitech.com/images/datasheets/standard_pump_models_100617.pdf)](http://www.microjet.com.tw/english/micropump.htm)
