Microcontroller compatible with the SparkFun Triad Spectroscopy Sensor - AS7265x (Qwiic)
I wanted to ask regarding the compatibility of the SparkFun Triad Spectroscopy Sensor - AS7265x (Qwiic). I am thinking of using the board with DOIT Esp32 Devkit v1 (it has a 3.3v output) using quiic connectors. Will it be okay or I have to buy something else along with the triad spectroscopy board to make it work?
Hi aksinghal, and thanks for posting.
We’ve never tested the AS7265x on that board, but it works on our ESP32 Thing Plus so it would likely work with the ESP32 board you have. Unless you solder pins to the AS7265x and jumper wire it over to your board, you’d probably want to use a Qwiic to breadboard cable like one of these below.
  • - [[Qwiic Cable - Breadboard Jumper (4-pin)](https://www.sparkfun.com/products/14425)
  • - [[Qwiic Cable - Female Jumper (4-pin)](https://www.sparkfun.com/products/14988)
  • [/list]](https://www.sparkfun.com/products/14988)](https://www.sparkfun.com/products/14425)
    Thanks a lot. Was helpful
