Hello - i recently got a MicroMod nRF52840 processor board and was expecting it to support have a UF2 bootloader. This does not seem to be the case; i was able to flash the board using nrfjprog but it would still be nice to have the convenience of UF2. Is there a way to update the bootloader?
It ships with the Arduino nano 33 BLE bootloader; you might be able to replace it following the steps mentioned later in guide and replace the hex with another, but you’d need to edit the pin #'s to match as well
https://learn.sparkfun.com/tutorials/mi … e-overview
So, not really, but if you do try and get it to work, post your process/experience here
