Hello!
I just obtained a micromod ATP carrier board and a Teensy processor card. I have a fair amount of experience programming the Teensy in its original form factor. I was excited to see the micromod for one reason: Debug. There is an SWD connector on the ATP card. I am so sick of debug printf()’s !
The Segger JLINK Edu Mini looked like a good bet. One that I could actually afford.
The ATP card doesn’t have the SWD connector stuffed, so I obtained one from another vendor, as well as the aformentioned Segger.
I was careful to install the SWD connector correctly, and NOT misclocked 180 degrees - which would be all too easy to do. And I verified that it was correct by ohming out the two ground pins. Yup, the correct pins.
Downloaded the Segger software - it says that the probe doesn’t support SWD !?!
OK, I tried JTAG. It complains t hat the TDO output is stuck high.
Has anybody got this working? The micromod platform is new to me, as well as the Segger hardware/software. There’s a lot of “hello world” stuff to resolve before I can get down to what I really want to do…
