Not able to program my new Micromod teensy on Micromod ATP Carrier board
I bought Micromod teensy with Micromod ATP carrier board lately. On connecting the board to PC the blue stat LED on micromod teensy blinks and on pressing the boot button on the board orange prog LED comes on. But when I open teensy loader and try to connect nothing happens. Teensy loader does not recognize the micromod teensy. I tried holding boot and connecting it and press holding boot for sometime as mentioned in internet, but didn’t work.
Please let me know if there is any other way to make it work or should i return the module back to vendor.
Make sure you also have the Teensyduino add on installed https://learn.sparkfun.com/tutorials/mi … ware-setup and re-test?
I also have a similar issue, for the first time it did work as said in the hookup guide.But now whenever i connect the processor to comp via atp board the program led blinks for two times every 3s continuously. I have tried the boot button and the reset button nothing seems to work :frowning:
How to hard reset it? did i brick the processor?help.
