Hi all. I have the Weather Carrier board with piggy back Artemis DEV-16401 along with the Weather Meter Kit.
These have been connected to a Raspberry Pi and recording data since 2021.
The RPi is in the garage
The Carrier is in an outdoor shield housing under the eaves
The Carrier is connected to the RPi with a long single USB-C cable
I just updated the RPi from “stretch” to “bullseye”.
Previously, the board worked, uninterrupted since 2021
After update, the system stopped working
The data-read program/script connects to /dev/ttyUSB0
USB0 now fails uart probe
When I first plug in the USB cable, I will see ttyUSB0 for under a minute before it disappears.
This is true for plugging it into either of the RPi larger USB ports.
‘dmesg’ has a sequence of messages about New USB device found
vendor 1a86
product 7523
bcdDevice 2.64
interface usbserial_generic
driver ch341
ch341-uartconverter detected
failed to send control message -32
ch341-uart probe of ttyUSB0 failed with error -32
USB disconnect
I am mainly an application software developer so not terribly familiar with the USB connection world.
Thanks in advance for any suggestions!
