Hello all,
I have made a PCB design using ESP32 PICO D4 and have attached the design below.
The frequency I would be working with is 2.4GHz. The datasheets of MCU and the antenna state that the output and input impedances are 50 ohms but many are suggesting me to add the impedance matching circuitry or design a proper Microstrip line.
Page 16 of MCU states - Output impedance is 50 ohms.
Antenna datasheet states - input impedance is 50 ohms.
If I have to design a Microstrip line please, Please do guide me how to do it in Eagle and what calculations do I have to make to do this. I am going to order my PCB from JLCPCB, so according to their capabilities suggest to me what values should I use.
https://i.stack.imgur.com/7Y120.pngAntenna Datasheet - [url = https://www.johansontechnology.com/data … 18A100.pdf
ESP32 PICO D4 Datasheet - [url = https://www.espressif.com/sites/default … eet_en.pdf
