Microview & arduino motor shield
I would like to know if an Arduino motor shield can be used with Microview?
Someone test it?
Can YOU connect two (or more) wires together?
jbesiga:
Someone test it?
Some pins required by the motor shield (D8, D9, D11, D12, D13) were not exposed on MicroView. You may need to use other exposed Pins to connect to the motor shield.
Hope this helps.
Cheers
JP
Thank you JP,
I have used others Pins to connect the Motorshield and works perfect!
Thank you
