Hi, making a PCB for production. The company whos gonna produce it told me they need 8 files:
.plc
.stc
.sts
.cmp
.sol
.dim
.drd
And an Info.txt file with dimension on board, Copper thinkness, nr of solder masks, soldermask color, list of gerber files and some more information.
Im using Eagle 4.16r2. When i want to generate the drill .drd file press: CAM, File, Open, Job, and select Excellon.cam And then process job. Then i get a .drd and a .dri file.
When i want to generate the rest of the gerber files i use gerb274x.cam instead of Excellon. And eagle generates 5 files:
.gpi
.plc
.stc
.sts
.sol
How do i create those last two files im missing. The .cmp and .dim.
And the info.txt file, is it something eagle can create or i just have to write down the info my self?
Any help is much appreciated ![]()
Thanks Morten
