MLF 32 pin chips doable???
Hello I am from UNC and I have a board that is using the MLF 32 pin atmel in the design. I am having issues with the DRC bot. I am looking for a place to post the files so people can see them… But a quick question would be, can I create the traces for mlf 32 pin chips?
-Casey
If you can help me please drop me a line at Kuhnscasey@gmail.com I will get you the files ASAP.
Ok if this works give it a try.
http://forums.delphiforums.com/n/mb/at. … &frames=no This should be the zip folder with all the files in it.
Please let me know the design name you submitted it under and I’ll take a look.
You can contact me at dcarne at this domain.
Cheers,
–David Carne
