Hi! I’m a newbie who’s had a blast putting together a Wi-Fi door lock using this solenoid: https://www.sparkfun.com/products/15324.
I wired up the solenoid with an ESP8266 Thing and other components on a breadboard. To connect the solenoid, I put some headers into the breadboard and jammed the end of the solenoid’s molex connector over the header pins. Now that it works, I’d like to start transferring the components to something a little less fragile. I’d like to solder down most of the components to a “solder-able breadboard” like this one: https://www.sparkfun.com/products/12070.
Where can I find a connector that fits with the molex connector on the solenoid and can be soldered down to a board? I haven’t had much luck finding one on the site. Alternatively, is there a set of connectors I can find that I can use to replace the one on the connector?
