I’m new to robotics and I’m currently trying to create a 2WD MOTOBit car using MicroBit. I have encountered two issues:
Items I am using :
Microbit
2Wd car chassis
2 IR sensors
1 Ultrasonic Sensor
problem Number 1: Line Following Robot Car
I have two IR sensors that I need to code. Although they’re correctly connected, I’m having difficulties coding them in MakeCode. Can anyone guide me? I have attached a picture for reference.
This SENSOR : https://www.google.com/url?sa=i&url=htt … AdAAAAABAE
Problem Number 2: Obstacle Avoidance Robot Car
I have an Ultrasonic HRC sensor with 4 pins, but the MOTOBit only has 3 pin inputs. Where should I connect the Echo pin? Also, I need help with coding for this setup.
I greatly appreciate any assistance. Thank you so much.
