It’s not a sound chip, it’s a MP3 decoder. Unless you have some sort of process to convert whatever sound you’re wanting to play into a audio file and then encode that as a MP3 on the fly and pass it to the vs1053b, it’s not going to work.
YellowDog:
Well, it has to have a DAC built in, how colud it produce audio output otherwise?
YellowDog:
I think it may not be necessary to encode to MP3 on the fly. The chip's datasheet [https://www.sparkfun.com/datasheets/Com ... vs1053.pdf](https://www.sparkfun.com/datasheets/Components/SMD/vs1053.pdf) has a section named "9.6 Feeding PCM data" on page 52, I thought I could maybe take advantage of that.
YellowDog:
I think what you’re after is a digital to analog converter chip like a SPI DAC or a breakout like the I2S audio breakout. Both are capable of converting digital sound data directly into an analog sound signal.
Thank you for the suggestion, though as I said in my original post I'm trying to be resourceful with what I already have.
