I saw on the MQ-131 ozone sensor datasheet that continuous vibration, such as on an assembly line in a factory, will lead to a down-lead response and then the sensor may break. Does anyone have data on what frequencies or duration will cause this? I’m including this in the payload of a large model rocket, and while it will be a short flight, I want to make sure the sensor can survive before I send it up.
Unfortunately we don’t have the data you’re looking for, the only way to tell for sure if it’s going to work in your application would be to test it and see.
