Ozone sensing - MQ-131
I’m trying to sense ozone, my range is 10ppb - 2ppm - the only part I found for ozone sensing is MQ-131 which comes in two versions low concentration and high concentration, the issue that even the low is not low enough, any suggestions? please help.
this is the low version: https://www.sparkfun.com/products/17051
SparkFun doesn’t have anything lower than the MQ-131 but Spec Sensors has some sensors that might work for you. Check the link below for their website. :slight_smile:
https://www.spec-sensors.com/
