Hello everyone,
I want to build a temperature logger system using a raspberry pi 4, to measure 8 spots in a simulation model, with the temperature range between 0-250 celsius degrees.
so I think the best temperature sensor is pt100 three wires connection for my purpose, and using a Mux (SparkFun Qwiic Mux Breakout - 8 Channel (TCA9548A)), in order to be able to connect the 8 sensors in the circuit.
my question is, is it necessary to connect an amplifier or ADC in order to get accurate readings? if yes, then do I need 8 of (Qwiic PT100 - ADS122C04) or one is enough?
is there any difference between ADC and Qwiic PT100 - ADS122C04?
thanks in advance
