I was testing a Light switch today that had 120V power ON with multimeter and had the meter incorrectly set to DC Auto. Big spark and I of course immediately removed probes (total contact time probably about 1/4 second - the amount of time for reflex to pull away from spark). 15 amp circuit breaker did not trip and multimeter still works as does the light switch. I replaced the light switch as a precaution since you could see what looks like an arcing spot on metal side of switch and a slight hot spot on one of the two wire screws, both where one of the probes had contacted. The multimeter probes look a little damaged but everything still works.
Concerned about whether the above might have damaged the house circuit wiring in any way. No sign of burned insulation or any other indication of any damage other than what I mentioned earlier and as I said, circuit breaker did not trip.
Appreciate any insights into what happened with my dumb move - learned an important lesson but want to better understand the physics associated with current flow and multimeters. Thanks in advance.
