Greetings Phil,
Agreed. That is perhaps the most non-intuitive operationPhilba:
I perhaps should have said “copy and paste”. It shows scissors for copy. You have to group select then click on “copy” (which looks like “cut” to a normal person) then it is in the copy buffer. There is no feedback that the copy operation actually happened. You can’t copy a single item (you MUST group select). This where modal UIs basically suck.
in the EAGLE GUI. However, it is consistent and
reliable, so once you have it mastered it works well.
You can lasso a single component, if fact you need only
enclose the component’s reference point (a small cross
symbol) to use the copy and paste function. Once it’s
on the clipboard you can place it on the same sheet,
another sheet, or even close the project and open or
start a new one, to place it. Another nice thing is being
able to stamp out multiple copies of the same clipboard
contents - a lot of “digital” design is repetitive.
Once I came through the initial steep learning curve
on EAGLE, I found many PCB related maintenance
tasks to be quite easy in EAGLE. In particular, starting
a new project by combining sections of other projects,
or extending a design to an extra sheet, or reworking
an existing design to update one or more parts.
I find EAGLE to be good value for my needs, and I’m
delighted to see that many new EAGLE user’s are turning
out good work on their first attempt. PCB tools are
not the same as Microsoft Office or other SOHO tools…
Comments Welcome!
