The school is using the “Retired” Kit-13897 and is in need of the “Power Control cables” for the class projects. Does anyone know where to find these or the connector mfg/part no. ? Thanks!
Hi Doug.
Is it the power pack you’re looking for?
Unfortunately we don’t carry those and [pi-top might be able to get you a replacement. If for some reason you can’t get a replacement through pi-top, the adapter they use is rated for 18 volts at 3 amps and has a 5.5mm x 2.1mm barrel jack on the cable with tip positive polarity. You might be able to find a replacement laptop power brick with the same ratings and plug from a computer repair shop.](https://www.pi-top.com/)
