Myoware sensor rechargeable battery
Hello, what is the smallest rechargeable battery I can use with the Myoware sensor? Alternatively, using the MyoWare power shield, can I use LIR2032 batteries and recharge them with one of these boards (click on the link)?
https://www.amazon.it/gp/product/B0778Z … Q7P7&psc=1
Thank you.
LIR2032’s should work and are in parallel on the shield so you should have no issues charging them. Those are 40mAh batteries though and you need a charger designed for a small battery. Using too large a charger may shorten their life or can cause them to explode.
