Need help: Sparkfun interface
I have a cricket scoreboard that has multiple (high amp) 7 segment replay controlled by 74HC595 shift registers with 74HC245 logic gate.
Each single PCB board has TWO 74HC595. to control 2 seven-segment led sets.
Each single PCB board has ONE 74HC245D 8-bit bus transceiver 10 pins in 10 out (with a logic of: A?,B? or keep going??)
The Cricket scoreboard chains these boards to display something like this
888 888 888
88 88 888
For a total of 8 PCB boards chained.
The issue:
The scoreboard is controlled via RF remote that is very “finicky” at best.
We want to bypass that interface and somehow use a RASPBERRY Pi(wifi) to control the SPI interface of 10 pins to the 74hc245 chips that are chained.
Any thoughts?
Here is an image of one of the 2 x 7-segment boards
https://drive.google.com/open?id=1ZlExc … fwyL_DVOMN
