Hello, I apologize if this is not the correct forum to use for this.
I’m doing some work with older Prius traction batteries, these are 7.2v 6 cell NiMH modules. I have a separate charger / balancer that I use with each module.
What I want to build is a data logger that will record the voltage and current as the battery is discharged / charged.
My thought is that I would capture the readings at the terminals of the battery. Log that data to usb thumb drive.
Any suggestions on where to start?
I’m thinking I need a board to measure current and voltage like:
KR Sense Current and Voltage Sensor - 90A
In stock SEN-16408
But I’m not sure about what to use to log the data.
Any advice would be appreciated.
Thank you.
-andy
