Hello support community,
I have been checking all manuals, examplse and going deep into the SparkFun_u-blox_GNSS_Arduino_Library to understand how the internal odometer in the library functions, but with no success. How can I call and access the odometer value?
Thanks a lot!
I have noticed the following functions in the library:
bool SFE_UBLOX_GNSS::resetOdometer(uint16_t maxWait);
bool getNAVODO(uint16_t maxWait = defaultMaxWait); // NAV ODO
bool setAutoNAVODO(bool enabled, uint16_t maxWait = defaultMaxWait); // Enable/disable automatic ODO reports at the navigation frequency
bool setAutoNAVODO(bool enabled, bool implicitUpdate, uint16_t maxWait = defaultMaxWait); // Enable/disable automatic ODO reports at the navigation frequency, with implicitUpdate == false accessing stale data will not issue parsing of data in the rxbuffer of your interface, instead you have to call checkUblox when you want to perform an update
bool setAutoNAVODOrate(uint8_t rate, bool implicitUpdate = true, uint16_t maxWait = defaultMaxWait); // Set the rate for automatic ODO reports
bool setAutoNAVODOcallback(void (*callbackPointer)(UBX_NAV_ODO_data_t), uint16_t maxWait = defaultMaxWait); // Enable automatic ODO reports at the navigation frequency. Data is accessed from the callback.
bool setAutoNAVODOcallbackPtr(void (*callbackPointerPtr)(UBX_NAV_ODO_data_t *), uint16_t maxWait = defaultMaxWait); // Enable automatic ODO reports at the navigation frequency. Data is accessed from the callback.
bool assumeAutoNAVODO(bool enabled, bool implicitUpdate = true); // In case no config access to the GPS is possible and ODO is send cyclically already
void flushNAVODO(); // Mark all the data as read/stale
void logNAVODO(bool enabled = true); // Log data to file buffer
