New user needing 360 degrees of coverage, which type, how many?
Hi…
New user about to order the “Sparkfun Inventors Kit v4.1 ( Redboard Quicc)” to experiment with those projects to get a better understanding.
https://www.sparkfun.com/products/15267
Ultimately after I have gone through the lessons. I want to make a spinning cat toy that will sense when one of our cats gets close and randomly spin around in different directions and at different speeds for a random amount of time until it sense movement again, etc. You get the idea.
I may add the “Sparkfun Proximity Sensor Kit” as I can use some elements in there regardless of the Sensor (if that wont work)
https://www.sparkfun.com/products/18448
But I may need a different sensor.
I’d like 360 degrees of coverage. But that there may not be a 360 sensor. so multiples will be needed.
Seems the “PIR Motion Sensor” may be a better fit.
https://www.sparkfun.com/products/13285
Does anyone know the “width” of view for the above “PIR Motion Sensor” Meaning how many will I need to get 360 coverage?
Also seems the “Sparkfun OpenPIR Sensor” has the customizable controller:
https://www.sparkfun.com/products/13968
Can I buy 1 “Sparkfun OpenPIR Sensor” to use for the adjustable settings and connect 1 or 2 (or how many needed) regular PIR Motion Sensors to that controller/board in order ot use the same settings of the “OpenPIR Sensor/Controller”?
I hope this makes sense. If not let me know.
Thank you all!
Geo
I might suggest getting the Proximity kit, and then also the OpenPIR sensor, then integrating them/experimenting to see which one, or if combining them, works best for detecting teh kitteh
The datasheet doesn’t mention its viewing angle https://www.sparkfun.com/datasheets/Sen … .pdf…but the demo in our demo video https://www.youtube.com/watch?v=ce23e96JlRk might be 18 inches or so?
Thank you for the reply!
Yes I tried looking at the datasheets before I asked.
You would think that would be in there.
Its a very common spec for home security PIRs and motion activated flood lights, etc.
