Hi there,
I’m trying to find out the coverage of the OpenPIR.
Is there any where I could find this out or does anyone happen to know? From other places I got
An approximate of 110 degrees by 70 degrees. Is this true?
Thank you
Hi there,
Thank you
The documentation is a little rough, I could not find a bill-of-materials anywhere.
The schematic gives lens part number Zilog Zmotion ZCWM05GIV1 datasheet here: https://github.com/sparkfun/OpenPIR/tre … umentation
Wall mount 100 degrees, ceiling mount 360 degrees.
Not sure what PIR sensor is used, or if it is oriented property. TO-5 can tab is the main axis and it might be rotated 45 degrees on the pcb for some reason.
