Hi all,
With some nice components from Spark Fun Electronics, I build the following setup:
Atmel Atmega168
Nokia 6100 display
SD card
DS18B20 Temperature sensor
Because of the low memory capacity of the atmega168 are the fonts for the display located at the FAT16 formatted SD-card. That works really nice ![]()
Okay, that was the introduction. The problem now is the following; since I added the temperature sensor to the system, I’ve some troubles with the contrast of the display. I had those troubles even before I added the sensor, but a lot less then now.
I determined the parameters of the “VOLCTR”-setting by tuning them for my system. But now, after reprogramming the system a few times, the display turns white or black and I have to adjust the contrast-parameters to get the display back on track. Another thing is that the displays contrast is a bit “flickering”. Does anyone have a solution for these problems?
Best regards,
Martijn
