Nordic FOB + USB ANT Stick ?
Hi
I get this item:
http://www.sparkfun.com/commerce/produc … ts_id=8840
and
http://www.sparkfun.com/commerce/produc … ts_id=8602
Is possible to test to each other with programmed firmware?
Any usb SW on windows for testing?
After plugin “Nordic USB ANT Stick” to usb not react at all???
I’m disappointed because two wires are broken!
:frowning:
http://www.sparkfun.com/datasheets/Wire … ck-v14.pdf
All see OK but broken are wires from fuse-F to pin20 FT232RL and D+ to pin15 of FT232RL!
must I check all connections? :frowning:
