waltr:
Yep, they work and is a very easy solution. I’ve used these to power a R-Pi and various PIC processors.
You do need to by-pass the Voltage regulator on the Arduino but this is easy to do.
The hard part is adding a USB connector to the processor board as you mentioned.
Why does one need to bypass the voltage regulator on the arduino? I’ve powered an arduino project this way before and it seemed to work well? Was I risking some sort of damage I wasn’t aware of?
Usually pumping a dc line through a VReg, ie lm1117 7805 etc, results in a voltage drop.
Eg, 7vdc into a 7805 typically comes out as 5vdc. So, I don’t know exact details of lm1117,
5vdc into a 1117 is going to come out at least down to 4vdc maybe 3vdc. So it could be
possible to power an arduino off 4vdc and maybe 3vdc, but it depends entirely upon the quality of components, tolerances of components etc eetc blah blah. Ie, some pcs can be overclocked and some can’t.
You might just be lucky to have a really well made piece of kit!
