Hi guys,
Can you please help me with a few problems below:
I am using mplab to program the microcontroller 18LF242 with a 3V button battery. Is it alright as I found out that sometimes the PIC doesnt run and the Vdd is actually between 2.6 - 2.9V ?
I dont receive any signals from the transmitter… ? I am not sure if is because of the programming codes? Below are the receiver and transmitter codes:
#include <p18f242.h>
#include <delays.h>
#define DATA PORTCbits.RC2
#define CLK1 PORTCbits.RC1
#define CS PORTBbits.RB1
#define CE PORTBbits.RB5
#define act_addr 0b10101010 //Addr
#define data_w 16
#define addr_w 8
#define crc 0b01 // CRC enable
#define mode 0b01001111 // Rx2En = 0, Shockburst Mode, 250kbps,16 MHz module crystal, 0db Power
#define rf_ch 0x00 // 2400 MHz frequency channel
#pragma config OSC = HS
#pragma config WDT = OFF
#pragma config LVP = OFF
void main()
TRISCbits.TRISC3 = 0; // ON PWR_UP
PORTCbits.RC3 = 1;
Init_RF();
while(1){
initInterrupt();
Rx_En();
void Init_RF (void)
char addr_w_crc = ( addr_w << 2 )| crc;
char config[15] = {0,data_w, 0, 0, 0, 0, 0, 0, 0, 0, 0, act_addr, addr_w_crc, mode, 1};
int i, j;
TRISCbits.TRISC2 = 0;
TRISCbits.TRISC1 = 0;
TRISBbits.TRISB1 = 0;
TRISBbits.TRISB5 = 0;
Delay10KTCYx(2); // 5 msec (tpd2sby)
CE = 0; // Set configuration mode
CS = 1; // Select configuration register
Delay10TCYx(4); // 10 usec (tcs2data)
for ( i = 0; i < 15; i++)
for ( j = 7; j >= 0; j–) // send the configuration
DATA = config >> j;
CLK(); // Clock in the data*
CS = 0;*
void Rx_En(void)
int i;*
char Rx_2400MHz = (rf_ch << 1) | 1; // configuration word*
TRISCbits.TRISC2 = 0; // Set Outputs*
TRISCbits.TRISC1 = 0;*
TRISBbits.TRISB1 = 0;*
TRISBbits.TRISB5 = 0;*
CE = 0; // Set configuration mode*
CS = 1; // Select configuration register*
Delay10TCYx(4); // 10 usec (tcs2data)*
for ( i = 7; i >= 0; i–)*
DATA = Rx_2400MHz >> i; // Shift out Rx address*
CS = 0; // shift the configuration word*
TRISCbits.TRISC2 = 1; // Set Data as Input*
Delay100TCYx(10); // 250 usec (tsettling)*
initInterrupt(); // Allow DR1 to interrupt MCU*
CE = 1; // Turn on ACTIVE RX Mode -
Delay10TCYx(4); // 10 usec (tce2data)*
void Receive (void)
int i;*
payload = 0;*
//CE = 0;*
for ( i = 15; i >= 0; i–)*
CLK1 = 1; // Clock in the data*
Delay10TCYx(10); // 500 nsec (tsetup)*
payload |= DATA << i; // Shift in payload*
CLK1 = 0;*
//Initialisation of Interrupt subroutines
void initInterrupt (void) { -
INTCONbits.INT0IE = 1; //enable INT1*
RCONbits.IPEN = 1; //enable priority interrupts*
INTCONbits.GIEH = 1; //enable all high priority interrupts*
void HI_isr_handler (void);
#pragma code high_vector_section = 0x08
void high_vector (void){ -
_asm*
GOTO HI_isr_handler*
_endasm*
#pragma code
#pragma interrupt HI_isr_handler
void HI_isr_handler (void){ -
if (INTCONbits.INT0IF ==1) {*
Receive(); -
INTCONbits.INT0IF = 0;*
void Off_interrupt (void){ -
INTCONbits.INT0IE = 0; //enable INT1*
RCONbits.IPEN = 0; //enable priority interrupts*
INTCONbits.GIEH = 0; //enable all high priority interrupts return;*
void CLK(void)
Delay1TCY(); // 500 nsec (tsetup)*
CLK1 = 1; // clock in the value*
CLK1 = 0;*
///////////Transmiter part//////////////////////
void main()
Init_RF();
while(1){
PORTCbits.RC3 = 1;
Delay1KTCYx(12);
Transmit(170);
Delay10KTCYx(100); // 250 msec
} // End void main()
void Transmit (int tx_payload)
int i;*
Tx_En();*
DATA = act_addr >> i; // Shift out Rx address*
DATA = tx_payload >> i; // Shift out payload CLK(); // Clock in the data*
CE = 0;*
void Tx_En(void)
int i;*
char Tx_2400MHz = (rf_ch << 1);*
TRISCbits.TRISC2 = 0; //Set as outputs*
CE = 0;*
CS = 1;*
DATA = Tx_2400MHz >> i; // Shift out Rx address*
Off_interrupt();// Disallow RD1 to interrupt MCU*
CE = 1;*
