nRF24L01+ and arduino
Hi all
First iam a noob in this arduino business
I will order it for a project we have
The project that I want one board to broadcast a signal for all time, then when a another board comes in range it receives this signal
So can I use nRF24L01+ to implement such function? And how to do it
Also I want the sending & receiving process to be as fast as possible because the other board will be passing the sending board
“Consider it like a check point for car racing”
Thanks in advance
Ps: sorry for poor English
You might be able to find nRF24L01+ code for the Arduino. If not, you will have to write your own. I did that for a PIC application, based on some Sparkfun code.
if its about the code no problem we can manage it , but what iam afraid is about the hardware
can this transiver do what i want ?
thank you so much for your reply
Range depends on the antennas, of course. If you use omni-directional antennas you should be able to do what you want.
Hi mahzero, i would know if you have the code for the nRF24L01 (tmb soy malo para el ingles :P)
