ODB-II ECU simulator for Macchina
I need to experiment with the Macchina A0 OBD-II Development Module, but need to do it from a desktop in a lab environment.
Can anyone recommend some ODB/ECU simulators compatible with ISO15765-4 ??? Pros/Cons?
thanks,
You might try posting this in the Macchina forum and see if anyone there has any suggestions for using a simulator setup
Take a look at the ECUsim 2000, I’ve used it in the past to test OBD readers and it worked pretty well.
https://www.obdsol.com/solutions/development-tools/obd-simulators/ecusim-2000/
