So while the facet is charging, every 5 seconds the light would do a faint blink and the blue facet logo would appear on the screen for a split second. I cant seem to upload this MOV video.
Waiting on sparkfun support to comment.
Is this the same device as the other thread?
No I was told this charging thiing was on the Rover and the Shut off thing was on the base
the user said it did charge. video is below
This is due to leakage current on the BAS16J diode used on the circuit used to power on/off the device and affects a select number of devices. It doesn’t affect the unit other than turning the display on briefly. I’ve documented the issue here: https://github.com/sparkfun/SparkFun_RT … issues/762 I suspect we can fix it in a future firmware release.
Thanks the customer seems fine with it. I consider this ticket closed.
