Does anyone have a schematic of the Olimex ARM-JTAG cable?
I’m looking for a schematic of this specific cable, not just any other Wiggler clone.
I have such a cable but I’m having a lot of trouble to get it recognised by OCDRemote. It only seems to work at the very lowest speed. My cable has a pin8-to-pin15 connection. I plan to make this cable work with open-source ARM-JTAG debugging software, but in order to do so I want to know exactly how the hardware is configured.
From my own experiments so far, the cable only seems to work when bits 4 and 7 of the data bus are high. I think bit 4 carries the nTRST signal, but what is the purpose of bit 7? (power/enable?) Also there seems to be some return signal on the ‘selected’ parallel port pin, but it’s not clear to me yet what JTAG signal it represents.
So, Olimex, can you release the schematics? Or at least a technical document that describes which signal does what?
